2019-11-11
08:53 PM
2023-05-19
03:47 PM
Gordana Radonic
2019-11-11 08:59 PM
2019-11-12 02:20 AM
2019-11-12 02:29 AM
Steven wrote:Why not migrate your old template?
We're creating a fresh template for AC 23 (having migrated the last few releases). Forgot how much work it is!
2019-11-12 03:05 PM
Lingwisyer wrote:Thanks Ling. Not as easy to find and edit as before. Also, The font size used to be in mm before, and now it's a point size I believe, so typing in the same values doesn't work. One more thing to figure out.
Circle Size: Drawing Title => Title And Frame...
Scale Text Size Drawing Title => Override Text Style... => Drawing Scale => Override Style
My Positioning tab seems a bit different... The Linked Width option toggles between the title being the width of the drawing box or a user defined width with the text right aligned with the end. Difference due to version?
Ling.
2019-11-12 03:20 PM
Barry wrote:Hi Barry. I've always understood and been told (by GS) that it's a good idea to start with a clean slate once in a while. I've done it twice in 13 years. There are legacy files and junk that gets moved when you migrate, and it's good to clean that out every so often. I think the last time we started fresh was when building materials came out.
I have used the same template for nearly 20 years (with modifications of course) and have never had trouble using my old template and re-saving in the newer version.
2019-11-13 02:25 AM
2019-11-13 02:15 PM
Steven wrote:Check Working Units... > Layout Unit. Choosing an imperial unit will show point size, metric will show mm.
2019-11-13 03:43 PM
2019-11-14 02:14 PM
