nusha
Drawing scale
Hi, I was wondering if there is a way to have graphic scale in my title / layout settings instead of having it written 1/4" = 1"
Thank you
7 Replies 7
Steve Jepson
Yes. There is a graphic scale bar in one of the Drawing Titles and also a Graphic Symbol.
If I knew which version of ArchiCAD you are using I could help you find it in your library.
nusha
Thank you, I found it in title settings. Now the trick is to have just it without the circle and the line. Also, the scale it shows - is it showing drawing scale or original scale? Can it be modified if necessary?
Steve Jepson
That would be in you Drawing Symbols library. There are probably 2 of them.
They will automatically change to show the scale the drawing or view is displayed in.
You can turn off the Numeric Scale Display if you like.
nusha
Ok, thank you
Steve Jepson
or like this. The setting looks a little different if your editing it as a Drawing Tile or as an in dependent object from the library.
Haneef Tayob
From what I can figure, this NCS Title is only on the US Library Container and not in the International release.
I'm now using AC19 Int and it still seems to be the case.
Haneef Tayob
Aziz Tayob Architects
AC23 INT rel 3003, OS X 10.14.6 iMac 3.3ghz i5 dual monitor, 24GB RAM
I couldn't find this NCS Title in ArchiCAD 20 3016 Int, but I did managed to find and extract the USA 20 library. Why this is not included as it is quite handy to have!
I've loaded the USA 20 library, despite the duplicate errors, but I'm having some trouble with how the graphic displays the alternating bars when used as a title block in layout. They are not solid black like in Steve Jepsons images. They look like they are using something else..!
I don't know if the layouts title block are related to the drawing title object:
or the scale bar, which shows a default solid fill as 'pavement 15'.
I not sure what I've done wrong in maybe adding the USA library or maybe something else is missing but I can't get the title block graphic bars to show as solid.. Help. Thanks
Ps. How do make or customise these title blocks?
