Vincent G_
Drawings title - Cross references
Hello,
In general on documentation, we document from large scale to detail scale. Typically Site plan > GAs > Zone plans > Area callouts > Details.
Same with sections, Overall building 1:50 > Facade section 1:20 > Facade details 1:5 > Construction details 1:2 /1:1.
I was wondering if I could have my drawing title's head marker referring to the previous/next zoom level, for instance my facade detail 1:20 showing where this callout/zoom comes from. So if my overall section is on the page called A3001, my facade detail section header would show the drawing number (# placed in the sheet) on top, and the reference to the overall section below. That would help a lot to make the connexion between drawings.
I couldn't find that option on the drawing title option (I'm using the native Linear Drawing Title 23 in AC23).
(see attachment 1) The 1/A6001 callout in the overall section is a Linked marker to The selected drawing. So the callout head on the overall section is showing the drawing # and the sheet ID of the facade 1:20 placed on the A6001 page.
I can assume I'll have to create a custom title? But what would be the trick to ensure a BIM information reading, like to make sure that this principle we have with callout reading a specific drawing is applied to the title header (not using customs).
The same would apply to the callouts I make from that 1:20 section into construction / typical details. On detail drawings page, each detail drawing would have its title head marker showing the drawing # on that page and the sheet ID of where that was called out
Does it make sense? Am I missing or not knowing an existing function that allows it already? Would love to hear your opinion about this.
3 Replies 3
Erwin Edel
We don't use drawing titles (we use autotext placed on the views instead), but I think there is an option for 'back reference': https://help.graphisoft.com/AC/23/INT/#t=_AC23_Help%2F070_Documentation%2F070_Documentation-100.htm
Are you trying to have multiple tiers of back reference, maybe? I think that might not be possible, currently.
There is also a (very old) method of manually setting a drawing as reference, placing autotext that references this and (supposedly) if you set a new drawing as reference after that, the already placed autotext still works with the old reference. This seems very archaic though.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Vincent G_
I'll check that link out on Monday morning, I'm already 1h30 unpaid over hour.. Hopefully that will provide me the solution! Otherwise I will either use autotext or a callout head referring back to the overall section. Thanks for the trick!
Vincent G_
Update on the cross referencing.
I got the same issue as this guy, and I could see you did reply to his post.
https://archicad-talk.graphisoft.com/viewtopic.php?t=52665
Basically, you can only back-ref the source markers of the drawings. My problem is that I want to back reference one section to another section, or a detail to a section. In my case, I want my facade detail section 1:20 to cross reference my overall building section. On my overall building section I created a linked detail callout, linked to the selected drawing: Section 1:20 placed on its sheet. I did try to link the marker directly to the viewpoint, but still couldn't select it on the back-ref dialog.
All I can back ref is the plans where the section's source marker is placed/shown, and I've even tried this trick but since it's linked marker kind of process I can't back ref them... :
https://archicad-talk.graphisoft.com/viewtopic.php?t=57053
So is there any way to show source section/elevation markers in sections and elevations? I mean by that the other sections that you might "see" on the section you're working in. Otherwise I can't see a way to back reference with this method.
And if not, do you reckon I could manage to create a title that would include a autotext refereeing to the drawing I want to refer to? I'm not certain what autotext/method you're using on your views, but could that somehow be included in a custom title header?
The issue I can already think of is how to make sure that each drawing having that custom title refer to the right reference, which is what the Back reference is doing. I don't get why we don't have the option to refer a linked marker..
