Hi.
well there is always different ways to do it.
1. try to update the drawings from the Drawing Manager, various (ou muitos) at the same time. it can save you some time.
2. If it keeps opening the external view in a new instance, try to open the original file, at the same time you have open the layout book. in this way it updates the drawings faster.
3. Sometimes there is a difference between "relative path" and "absolute path" when you link the external views... check it, compare those two, maybe you can find something new.
Please come back with your solution... i haven't solve the problem at 100%
Cheers !
Nando Mogollon
Director @ BuilDigital
[email protected]Using, Archicad Latest AU and INT. Revit Latest (have to keep comparing notes)
More and more... IFC.js, IFCOpenShell
All things Solibri and BIMCollab
