Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
SOLVED!
Edit model display setting across multiple 3D docs at the same time
Yvonne
Is the possible to edit all the model display settings in multiple 3D docs?
Or pick up/inject settings like you would for views?
AC26 | Win11 | 64 bit | 32Gb RAM | Intel i9-9900K @ 3.60GHz
1 ACCEPTED SOLUTION
Solution
Yes, it can be done.
Activate the Project Map (not the View Map!), and select all 3D Documents you want to modify with CTRL/SHIFT-clicking them as you would normally do in your file system. Then right-click and choose "3D Document Settings". The changes you make will be applied to all selected 3D Document Viewpoints.
1 REPLY 1
Solution
