Edit model display setting across multiple 3D docs at the same time
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2021-04-08
06:46 AM
‎2023-05-19
11:35 PM
Gordana Radonic
‎2021-04-08
06:46 AM
Is the possible to edit all the model display settings in multiple 3D docs?
Or pick up/inject settings like you would for views?
AC26 | Win11 | 64 bit | 32Gb RAM | Intel i9-9900K @ 3.60GHz
Solved! Go to Solution.
Labels:
- Labels:
3D Document
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-04-11 11:27 PM
‎2021-04-11
11:27 PM
Yes, it can be done.
Activate the Project Map (not the View Map!), and select all 3D Documents you want to modify with CTRL/SHIFT-clicking them as you would normally do in your file system. Then right-click and choose "3D Document Settings". The changes you make will be applied to all selected 3D Document Viewpoints.
1 REPLY 1
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-04-11
11:27 PM
