RandyC
Element id - advancing numbers
How can I set my walls so the numbering - does not advance ?
Thank you , Randy
ArchiCAD 4.5 --- 27 , Win 10 , dual monitors, 64 gb ram,Nvidia GeforceRTX 2080 TI, I-9
1 Solution
Just uncheck the box for "Assign New Element ID to Each New Element" in your Work Environment > User Preference Schemes > More Options panel as shown in the attached screenshot. As with all Work Environment panels, save your scheme and profile with a name so that you can quickly get those settings back if changed, or take your settings to another workstation.
Alternatively, so that you can have some elements with auto-increment and some without, leave the box checked and note that If, when you start placing elements with a tool, the ID field contains one or more numbers - however they are separated ... the last number will be incremented as you place additional elements. If the there are no numbers in your ID, nothing will be incremented.
If you later need to rename and/or renumber placed elements based on search criteria, the Element ID Manager can do that for you. See:
https://helpcenter.graphisoft.com/guides/archicad-21/archicad-21-reference-guide/documentation/calcu...
Go to post
5 Replies 5
RandyC
Thank you Karl -- I thought there must be an easy way
The Element ID transfer settings looks a bit confusing however , do you know
of a tutorial on using this ?
Thanks, Randy
You're welcome.
Not sure what your next question is. I mentioned the Element ID Manager in my post. The only transfer settings capability is the eyedropper / syringe = Element Transfer Settings, which can be customized to only transfer specific settings from one element to another. Help topic and videos here:
https://helpcenter.graphisoft.com/guides/archicad-21/archicad-21-reference-guide/interaction/editing...
RandyC
Sorry i said it wrong I meant "Element ID Manager"
is there a tutorial on how to use this manager?
furtonb
This might be useful from Eric Bobrow:
https://www.youtube.com/watch?v=5KHkh6vcuZA
This other deals with the topic of labeling, but from 17:25, there is an example for the use of the ID manager.
https://www.youtube.com/watch?v=s_8czLAbuJA
odv.hu | actively using: AC26-28 INT/HUN - multiple builds | Rhino6-8 latest build | macOS @ apple silicon / win10 x64
