Elements Rotated By Default When I Place On A Layout
JamesBell
Hi there,
Whenever I drag a view, pdf, anything on to a layout, it is placed on rotated angle instead of 0 degrees
Does anyone know why this would be happening?
Thanks,
James
Because you have told it to be placed on an angle.
Reset the default tool settings to 0° before you place the next drawing.
Thanks Barry!
