Elevation Issue - Do need your help and big thanks!
Hey everybody.
1. can i ask what is the difference in "fill uncut surface with-own surface color(NON-SHADED)" and "fill uncut surface with-own surface color(SHADED) under the elevation? i cannot tell the difference from the image attached.
2. May i know how to make the color a little big lighter or transparent? coz now the color is too dark and solid, which is a bit disgusting
Big thanks!!!!!
15 REPLIES 15
Help! Help! Help!
How the make the shaded color lighter???
How the make the elevation shaded color lighter?
like the attachment, I would like to make the color lighter so that it does not look that strong
Anybody know?
thanks!!
help~~~~~~~~~~~~~~~~~
Eduardo Rolon
From the reference guide using search term "shaded".
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
Eduardo Rolon
Color is controlled under the Surface Settings
AC28 US/INT -> AC08
another Moderator
Eduardo Rolon
If you need transparency, I would not use elevations or sections for the drawings. I would use 3D Documents.
The reason is that if you turn Transparency on for S/E it will affect all drawings while 3D-Doc is an item for each view.
AC28 US/INT -> AC08
another Moderator
Eduardo Rolon
3D Doc.
AC28 US/INT -> AC08
another Moderator
Eduardo Rolon
Elevation from 3D Doc.
AC28 US/INT -> AC08
another Moderator
Eduardo Rolon
Edit the 3D Sun Settings to get more light
AC28 US/INT -> AC08
another Moderator
