Elevation Markers according to Reference Level
Hobbesnb
Is there a way to make the story markers in an elevation display their elevation heights in relation to a Reference level (ex. Sea Level), rather than Project Zero?
Scott Graham, AIA LEED BD+C
Principal | BIM Manager
Muhlenberg Greene Architects, Ltd.
Wyomissing, PA 19610
V6.5-26.0
7 REPLIES 7
Hobbesnb
That's not exactly what i meant.
I'd like the story markers in the ELEVATION VIEW (i.e. - +5.25') to show their elevation values as relative to a reference level (sea level for example) rather than project Zero.
Accidentally put this thread under the wrong heading, sorry.
V6.5-26.0
I don't believe so (I've created a custom Story Marker to do this).
Oosh
Is there a way to show the elevation from project zero AND sea level in section/elevation with the dimension tool or a .gsm object?
AC26 5004 | MacBook Pro (16-inch, 2023) | Sonoma 14.0 | Apple M2 Max | 32 GB RAM
Oosh:
Yes. Select the Dimension text and change it from Measured Value to Custom Text, where you can add Autotext that references Project Zero and Sea Level.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thanks, David! This is what I was looking for.
Oosh:
Good to know, thanks for posting back.
