Elevation Settings Not Working
Hello. I'm having this problem lately about the elevation settings from Archicad 19 version which I'm working right now. When I try to change in Model Display > Cult Elements > Uncut Elements, everything... nothing doesn't apply to the elevation, like if it's locked but it's not, all layers are unlocked. So for example in Uncut Elements, I want to change Uniform Pen Color to Own Surface Colors (shaded), and when I choose it, it changed the icon I press ok, and then nothing happened in the elevation and when I re-open the elevation settings it's still the same as before, like I never chose anything.
I'd be very thankful if someone could help me
Regards
Álvaro
Alfaro,
Sounds like you are opening elevation from a saved view, a saved view will remember the saved settings of the elevation and apply them to that view.
You will need to make your changes and then update the saved view to use current settings.
Scott
