Elevation levels overlapping. How to adjust them?
Have this issue and have no idea how to fix it.
16 Replies 16
Polar Bear
I am having the same problem.  Coming from Revit, the elevations levels are fully adjustable.  Why we like to link certain element to it, for exemple, concrete lintel in a stabilised earth building: to adjust levels as design progresses (BIM basic function).
So i guest it's a work around to "hide" the elevation or simply not use them for mid-way structural elements.
Archicad 25 - 5010
Macbook pro 13" /Big sur 11.4 + External 4K 27"
There is a free Story Marker which I think will solve this issue. It looks like it is already updated for AC25, with previous versions also available:
https://www.indigofigs.com/story-marker/
Not free.
Screen Shot 2021-11-06 at 10.38.10 PM.pngScreen Shot 2021-11-06 at 10.37.54 PM.png
Ah, OK, sorry, I remembered that it used to be free, seems like it is no longer the case.
Realised post-facto: previous versions (up to AC24) are free. I don't know if there is anything in the script stopping one from using the AC24 title on AC25. In any case, it is free for AC24.
Polar Bear
Thanks a lot!
Archicad 25 - 5010
Polar Bear
I have looked at the indigo marker, and even that isn't so easy grab and aranged.  I was looking at a revit like easiness of customizing the level marker...
Archicad 25 - 5010
