‎2004-05-02
02:33 PM
‎2025-02-10
04:39 PM
Aruzhan Ilaikova
‎2004-05-02 02:56 PM
‎2004-05-05 08:19 AM
‎2004-05-05 09:11 AM
Todd wrote:I have found this error can occur when Plotmaker crashes ( like when trying to move an importing file) and the only way to fix things is to restart.
Error while reading file: Main level 1_8.pmk
(256: File is not found, connection failed)
I'm getting this error message whenever I try to import anything into Plotmaker, on this house I'm doing. It started happening after I cancelled an import earlier.
How can I repair this? Deadline looming!
It's a problem with the ArchiCad file. Even a new Plotmaker file cannot import anything from this file.
I tried merging the Archicad file into a new and reset file. Tried importing that into a virgin Plotmaker file. Same error.
‎2004-05-05 10:32 AM
Aussie wrote:. . . or a 'send and receive' on the teamwork file (if you're using one) sometimes clears it.
