Error when importing into Plotmaker
Error while reading file: Main level 1_8.pmk
(256: File is not found, connection failed)
I'm getting this error message whenever I try to import anything into Plotmaker, on this house I'm doing. It started happening after I cancelled an import earlier.
How can I repair this? Deadline looming!
It's a problem with the ArchiCad file. Even a new Plotmaker file cannot import anything from this file.
I tried merging the Archicad file into a new and reset file. Tried importing that into a virgin Plotmaker file. Same error.
4 Replies 4
OK... Strange.
I quit ArchiCad. Quit BGArchicad. Quit Plotmaker.
Started up Plotmaker, open the PM doc., and it imported the AC file just fine.
I guess I don't understand what BGArchicad really is. I can't work on the AC file and PM file anymore?
Follow these links....They may or may not help....I hope they do!
http://archicad-talk.graphisoft.com/viewtopic.php?t=2305
http://archicad-talk.graphisoft.com/viewtopic.php?t=2510
Aussie John
I have found this error can occur when Plotmaker crashes ( like when trying to move an importing file) and the only way to fix things is to restart.
Cheers John
[/size]
__archiben
. . . or a 'send and receive' on the teamwork file (if you're using one) sometimes clears it.
b e n _ f r o s t
