2023-11-09 12:00 PM
Hello. With the arrival of more and more complex elements, first railings and stairs, then beams and columns, we are running into problem when creating schedules. We use some general schedules that lists most 3d objects to check their properties and data values, but only care about the top element, not the sub-elements (i.e. rail end, column segment, handrail connection etc.). However in schedules they all show up unless specifically excluded, and there are many.
So I was wondering if there is a method or some property to separate top level elements from sub-elements, especially moving forward if more and more tools will be reworked in this way.
2023-11-09 03:09 PM
Already posted in wishes... https://community.graphisoft.com/t5/Wishes/Add-sub-element-option-to-selection-criterias/m-p/574282#...
2023-11-09 04:11 PM
Ah okay, great. Let's hope for some progress.
