Explode Complex Archicad Elements v20
In v19 if I set up my save filters for dwg files I could set the option in the "Save Floor Plan" option under the "Save Options" option to "Explode complex ArchiCAD Elements".
That is no longer an option under v20. How is this now handled?
2 Replies 2
David Maudlin
mbeam:
It shows up in my version.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thanks for the answer, it help me figure out what I was doing wrong. I had the 3d window of that particular project active when I tried to to a save-as to set up my filters (just started using v20). If I have a 2d window active it displays a different dialog with the mentioned option showing.
