Mats_Knutsson
Mentor
Export to pdf yields wrong dimensions
It's small but however I don't understand where the "clutter" comes from.
/Mats
AC 25 SWE Full
1 Solution
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Dear All,
Thank you very much for your opinions about this issue!
I looked into our system and Mats's question was answered by our colleague. Here is our developer's explanation:
1. The standard error tolerance in Archicad is 0,01mm, which seems absolutely tolerable in a building. Most of our codes don't work more precisely than this.
2. If you print to a virtual PDF printer, the difference will be larger. In the print workflow precision is less important than drawing the whole requested area, including the lines on the edge. For this reason, we use a pixel-size rounding down in the page size, so in the worst case, the page content will be smaller a little bit. The size of the difference is the same as one or two pixel's size. Therefore the proportion of the difference depends on the resolution and the page size as well, but generally is 0.1-0.2%. On a printed paper the one pixel difference on a whole page is totally unrecognizable. However if you print to a virtual printer and then measure the size, you can find it.
If you want to bring the PDF back to Archicad and 0.1-0.2% difference is not acceptable, we recommend directly save the layout/view as PDF or use Publisher function instead of a virtual printer.
I hope this explains the situation. Please let me know if you have any questions!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Go to post
12 Replies 12
Is it because of the round end to lines in Archicad?
Mats_Knutsson
Mentor
I sincerely hope not. I've sent it to our local rep support.
AC 25 SWE Full
Mats,
PDF exported for Archicad is typically more accurate than that exported from Autodesk products, whenever I check a PDF in Bluebeam from Archicad they dimension correctly but from either AutoCAD or Revit there is a small discrepancy (up to about 1mm / meter)
Scott
Mats_Knutsson
Mentor
sboydturner wrote:
Mats,
Scott
Good but doesn't help me 😉
AC 25 SWE Full
Erwin Edel
Isn't this the result of scaling something to a papersize (assuming you are measuring something on a PDF with other software)?
Somewhere in the magic of DPI, PDF file format etc etc something gets lost?
Something like IFC or DWG should yield better result for 3rd parties checking dimension etc
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Mats_Knutsson
Mentor
yes pdf...which is what we use more and more. Clever programs should have the ability round numbers. Just curious where this comes from . No answer from GS support yet.
AC 25 SWE Full
Erwin Edel
For what it's worth: I notice the same issues when exploding a vector PDF in Archicad: the dimensions are no longer 100% accurate. I assume it has to do with changing things from a 1:1 scale to a 'grid' of 300 dpi (or whatever setting your PDF uses) on the page size.
I'm not sure if there is much that can be done about it on the Archicad side of things.
www.leloup.nl
DGSketcher
Legend
As Erwin said there is a translation to PDF compromise. I frequently have to work from vector PDFs and rely where possible on the displayed dimensions. In my experience you cannot rely on the PDF vectors which will always have potential errors. If you want to share reliable 2D data save the view to DWG, (until GS sort out reading PMK files in different versions of AC. ).
Mats_Knutsson
Mentor
It's more a general question concerning all users of pdf's. Have to live with it I guess. The use of pdf's in digital apps is booming while we print much less. Mega-pdf + Dalux/Streambim/similar is the way to go..."paperless" projects.
AC 25 SWE Full
