SOLVED!
Exporting 3d views - separately just lines and just shadows
olga_kots
Hello,
I need to export 3d views only countors and only shadows.
The problem with countours - is that despite the ways - its always bad quality, but I need to have it perfect in order to work with each line in Photoshop or in Illustrator.
And with the shadows - I havent found any way to export them.
Seems like those options are only possible in Sketchup.. (attached how I need them to be)
I hope there is a way, since we need those functions to create collages.
And its super incovenient to export to sketchup to get these just these two layers.
Thanx in advance
undefinedundefined
OLGA_KOTLYAROVA
1 ACCEPTED SOLUTION
Solution
Emre Senoglu
I think one way to do this would be to create a 3d document from your view. You would then create a worksheet from this 3d document, and open the newly created worksheet. You can then select all the lines and move it to the side or on another worksheet. Same with fills, you can filter the fills to select only the ones with gray tones (shadows) or white tone (building geometry). Then it's just a matter of exporting as a format that would be useful for you - dwg or ai.
Also make sure that your glass material is %100 transparent before creating the 3d document as it is crucial for having the shadows display properly.
Here's a video showing how: https://capture.dropbox.com/4tg4VDO1KS8r1hRA
AC27 ARM // MBP M2 Max // Twinmotion | Corona | Rhino
www.senoglu.co
3 REPLIES 3
Solution
Emre Senoglu
www.senoglu.co
Eric Babron
Hello,
you can also:
go to the 3D window, and set it to "Vectorial engine"
with the marquee tool select what you need
go to the edit menu and select "copy", you will have a menu to choose what you want to copy: see:Help Archicad 25
Architect
AC9 - 26
Win 11
Thank you, Emre!
Can't express how much I appreciate your help! You've made my day!
OLGA_KOTLYAROVA
