‎2009-02-19
09:55 PM
‎2023-05-26
02:31 AM
Gordana Radonic
‎2009-02-19 10:40 PM
‎2009-02-19 11:48 PM
Patrick wrote:Create a Pen Set with all pen weight values set to 0 (zero) and assign the smaller Drawing this Pen Set.
Once a drawing is complete, is there a way to make it print all hairline if it's used in another layout at a MUCH smaller scale?
‎2009-02-20 04:55 AM
Laura wrote:Only caveat I would add here is something mentioned a couple of years ago on these forums - not sure by whom, Duane Valencia, David Larrew, Eric Batte??? Someone back then reported that they had a new fancy laser wide format printer that printed at 1200 dpi (or higher?) and that if they used a pen width of zero, the line was so thin that when someone tried to make copies of the drawings, those lines would not reproduce.
