2013-12-1005:52 PM - last edited on 2023-05-2612:18 PM by Rubia Torres
Fill Categories in 17
2013-12-1005:52 PM
Previous version allowed categorization of fills directly from the Info Box: Drafting, Cover and Cut.
These buttons are gone, I see no way of adding them back in the work environment.
Attribute Manager allows fills to be used as any or all categories. (Does this mean that if a fill is set to be both a Drafting and Cut fill, it will still show when Model View Options are overriding one of the categories? Read on...)
Fill display in elevations is then limited by Model View Options. However, overriding Construction Elements fills in Elevation also overrides drafting fills: No fills are displayed.
The icon to the left of the fill popup is now a button. Click and it will show you the filtering options.
The fill categories was only a filter, so the functionality hasn't change but it's now more logically placed in front of the popup. And of course we added Building Materials into the Fill as of AC17.
