Fill Pattern Wanted
Does anybody here knows of a source for additional Vectorial fills or Simbols fills.
I could use some symbols for stone or concrete pavers not to be found in the avilable list.
Win 10 Home Premium - AMD Phenom IIX6 1090T Processor 3.20 GHZ 8.00 GB RAM 64-bit Opp. Sys NVIDIA Quadro 4000 AC 22, MEP
Hello Conrado Domingue,
I do not know if there is an additional Vectorial fills or symbols fills but it is so easy to create your own that I use to do it for each of my project.
About creating a hatch :
Create a pattern with lines (with a picture under the lines for example)
Copy theses lines
Open hatch window
Paste your pattern into a new symbol hatch
Enjoy your new hatch
Christophe - FRANCE
Formateur Archicad indƩpendant Ơ NANTES
Archicad 15 to 29 FRA FULL
If you Google .PAT and pavers, you will find many, many potential fills. e.g. https://www.angeluspavingstones.com/category/layout-collection/standard-layouts/ . If you don't have a way to create a DWG using the .PAT files and then import the DWG file into ArchiCAD, you can place the PDF, explode it, and then paste the lines into a new symbol fill as Christophe suggested.
Richard
AC26 (since AC6.0), Win10
