2021-03-12
		06:28 PM
		2023-05-26
		02:20 AM
			Gordana Radonic
Solved! Go to Solution.
2021-03-12 07:22 PM
2021-03-12 07:22 PM
2021-03-12 07:35 PM
LaszloNagy wrote:
It cannot be the "Make Fills & Zones Transparent" button in the Trace & Reference Palette because that would make it transparent, not white.
As far as I could figure out, I can think of two possible causes:
1. The active Renovation Filter overrides the Fill, and the override style is set to override the Fill with a solid white fill.
2. In your screenshot, the Info Tag says that there are multiple elements there. So there may be a Slab there, which is in front of the Fill in Display Order, and it has a white solid Cover Fill, which hides the fill color of the Fill element behind it.
