Rve
Find and select fills on multiple views at once
Is it possible to ‘find and select’ fills in multiple views at once? I’d like to add an element ID to a fill that is used on multiple views. Please help
1 Solution
No, you can only work in one view at a time, so you will only be able to select the fills in one view at a time.
Unless that are all in plan views (different storeys).
Then you could create a schedule that lists the ID and you could change them all in the schedule.
You can't schedule fills in sections, elevations, details or worksheets, so that won't work for them.
Go to post
2 Replies 2
Rve
Thank you @Barry Kelly for the feedback
