2007-08-2702:04 AM - last edited on 2023-05-3003:21 PM by Rubia Torres
Floor Tile Dimension
2007-08-2702:04 AM
i am trying to get the exact dimension for floor ceramic tile (600 x 600) in a rendered picture. i've tried resizing the original picture and croping it, but when rendered, i still look like a (1000 x 1000) tile. can someone help me with this.
Did you resize the tile for the rendering engine that you are using?
It is a common error to size images using the internal rendering engine while trying to render with LightWorks.
Compare the material files.
Also try "Match With Internal Engine." This attempts to use the internal engine settings in LightWorks.
