2024-05-07
12:53 PM
- last edited on
2024-05-09
01:05 AM
by
Hello everyone,
Please help! I'm trying to make a rooftop plan. I want to hide some of the yellow lines that represent Basement walls - the one surrounding the pool should stay but the other one that is below a slab should be hidden.
How to make that happen ? If I set the RELATIVE FLOOR PLAN RANGE to 0 stories below , it will hide all of the basement walls and the pool will not have outlines.
I thought of using a slab white fill in order to work around this. Any other , better ideas ?
Solved! Go to Solution.
2025-10-31 12:34 PM - edited 2025-11-04 08:19 AM
I have been running into the same issue a lot and its always this lame combine on layout workaround, this needs to stop. GS should get their stuff together and fix this story based mess that does not allow any stramlined workflow for projects that do not use a single storey reference system (eg the most basic common task of 2 (two) houses on a different ground level)
