Floor to Floor Dimension
dhnguyen
Is there a way to automatically show the floor to floor dimension instead having to manually create a dimension string for it? I wasn't able to find it in the Elevation Settings.
Please see attached. Thank you
DNguyen
ArchiCAD 18- 25
(expert in AutoCAD, novice in ArchiCAD)
Not that I know of.
Maybe it is possible to do it through the ARCHICAD API, but for that, you would have to be able to code in C++.
LucaP
I don't think there is an option for levels - only for axes. Good news is that whenever you click on story level (level line, when cursor turns into tripod), in section or elevation, it should select all the levels automatically, so you don't have to click on each story.
Hope that helps you in some way.
Łukasz Pietraszko
ArchiCAD 26 PL, since AC20 | WIN 10 Home
Intel Core i7-7700HQ 2.8 GHz | 16 GB RAM | NVIDIA GeForce GTX 1060 6 GB | 500 GB SSD
