‎2014-06-25
02:57 AM
‎2023-05-19
03:56 PM
Gordana Radonic
‎2014-12-02 07:57 PM
‎2014-12-22 01:46 PM
Barry wrote:..and every master layout that hasn't caught up with your new 'compatible' template,
I'm not sure about a fix but to select all text at once activate the text tool and then CTRL+A (or the Mac equivalent).
You could also use the find & select tool.
You will need to do this for each storey, section and elevation though as it is not possible to select all text in all views at once.
Do the same for your dimensions (dimension tool then CTRL+A).
If you have objects with text in them then you will have to select each one and change them manually.
‎2015-06-22 03:25 PM
KatalinBorszeki wrote:I'd like to raise this issue again. I haven't seen the final result of Graphisoft's discussion, and I don't know its status in Archicad 19, but the problem still bites us. We have projects dating all the way back to the early 1990-ies (Archicad4 something), and now and then some of them pop up for a revision or addition.
Hi All, let me post a correction with regards to the previous comment on PostScript Font Types.
For now, the PDF engine does not support them, but Graphisoft is still discussing the future of how these Font Types will be handled.
Thanks!
‎2015-08-05 08:34 PM
Thomas wrote:I am constantly running into this issue as well. We are not going to change fonts. Too many projects to change. It's a total pain having to manually save each and every sheet. I need each sheet to be an individual PDF otherwise saving multiple sheets as one PDF works fine - all fonts show up but this is not our way. Graphisoft/Progammers/Makers of ArchiCAD - What's the status on this?
So please, Graphisoft, I'd like some information. What will you do?
‎2015-08-06 03:28 PM
junior wrote:If that works the same on the Mac, it should be possible to edit some .plist file to the same avail.Thomas wrote:...I see there is a workaround for Windows but none for Macs (though I can't say I like the idea of increased PDF file sizes as result of this fix): Missing text in PDF published from ArchiCAD 11 or higher
‎2015-08-10 01:50 PM
‎2015-11-06 05:37 PM
Hi All,
This was a problem that was caused by the new PDF engine built into ARCHICAD 18. As for the process involved, the "publish PDF" is using the PDF engine, while the simple "print PDF" command is completed by the operation system. That is why the print command did not cause the fonts to be lost in the PDF.
WE have listened and heard the complaints of our users and went around the problem in ARCHICAD 19. The fix had an ARCHICAD 19 target and is not planned to be implemented in ARCHICAD 18.
Let us know if you have any more questions or comments,
k
‎2017-06-23 08:40 PM
‎2017-06-23 08:50 PM
genarch wrote:It was not fixed in 19, though it seems to be fixed with the latest version of 20 (6005). No issue in 21, so I think we can finally lay this one to rest. (Not if you are still in 19, however.)
Was this fixed for anyone in ArchiCAD 19? I'm using 19 and I still have the missing font issue.
‎2017-06-23 08:55 PM
