2004-03-01
05:55 AM
2024-05-03
01:44 PM
Aruzhan Ilaikova
2004-03-03 09:23 PM
2004-03-04 12:09 AM
2004-03-08 01:20 PM
2004-03-08 11:53 PM
How to See Foreign Characters of library parts in the Object Settings Dialog
Written by Balázs Biacs
How to see foreign (i.e. Russian) characters of library parts in the Object Settings dialog if using international ArchiCAD
E.g. the library of the Russian version 6.5 does not show russian letters when used in the international verison 7.0.
Do as follows:
Quit ArchiCAD.
Open the Registry editor. [Start menu/Run.../type "regedit" and run it]
Open the key:
HKEY_CURRENT_USER/Software/Graphisoft/ArchiCAD/ArchiCAD 7.0 INT/Font Description
Choose Font Script Code [doubleklick on it]. A small dialog appears: Edit DWORD Value.
First set the radio button on the right to the Decimal position, then enter 204 into the Value Data field, then choose OK.
Now if you open Your ArchiCAD 7.0 International, all menus will be displayed in English, but you'll have the Russian characters in the Object Settings dialog. If you would like to revert to the International settings, set the same value to 0 again.
Other values for other character sets:
ANSI_CHARSET 0
DEFAULT_CHARSET 1
SYMBOL_CHARSET 2
SHIFTJIS_CHARSET 128
HANGEUL_CHARSET 129
HANGUL_CHARSET 129
GB2312_CHARSET 134
CHINESEBIG5_CHARSET 136
OEM_CHARSET 255
JOHAB_CHARSET 130
HEBREW_CHARSET 177
ARABIC_CHARSET 178
GREEK_CHARSET 161
TURKISH_CHARSET 162
VIETNAMESE_CHARSET 163
THAI_CHARSET 222
EASTEUROPE_CHARSET 238
RUSSIAN_CHARSET 204
MAC_CHARSET 77
BALTIC_CHARSET 186
2004-03-09 12:35 AM
2004-03-09 04:35 AM
2005-11-13 02:53 PM
2007-03-21 03:43 PM
2007-03-24 04:40 PM
