mhoude
GRID ELEMENT AND WORKSHEET
Hello all,
Why grid element are exploded went you extract a worksheet from the plan ??????? Label still label
3 Replies 3
Podolsky
Ace
Well, technically because grid tool is a library part, as furniture or any another element. It just uses built-in Add-On, that represents this element as separate tool. So Archicad explodes all structural elements including library parts. Label is 2d element - so Archicad shows it how it is - I don't remember, does Archicad explode for example dimensions into lines and text, but seems all annotations elements Archicad just transfer how it is into worksheet.
mhoude
Dimensions are not exploded and grid element is a tool just like section and elevation. It should keep is native
Podolsky
Ace
no grid tool is not the same as section elevation. it's gdl object attached with add-on. not completely native tool.
