‎2022-02-22 08:00 PM
Hello all,
Why grid element are exploded went you extract a worksheet from the plan ??????? Label still label
‎2022-02-22 08:54 PM
Well, technically because grid tool is a library part, as furniture or any another element. It just uses built-in Add-On, that represents this element as separate tool. So Archicad explodes all structural elements including library parts. Label is 2d element - so Archicad shows it how it is - I don't remember, does Archicad explode for example dimensions into lines and text, but seems all annotations elements Archicad just transfer how it is into worksheet.
‎2022-02-22 09:06 PM
Dimensions are not exploded and grid element is a tool just like section and elevation. It should keep is native
‎2022-02-23 07:35 PM
no grid tool is not the same as section elevation. it's gdl object attached with add-on. not completely native tool.
