2016-12-17
09:10 PM
2023-05-30
12:25 PM
Rubia Torres
2016-12-17 09:22 PM
2016-12-17 09:37 PM
Richard wrote:yes, everything is on.
Is the layer on that the grid markers are on? If you go into the default settings for the grid elements, and open up the "Section/Elevation" drop-down, you have "Markers" checked?
2016-12-17 09:39 PM
Archimamamia wrote:Is there a 'work around' where I can go in and set them up in the Section, am under the gun to get this out....Richard wrote:yes, everything is on.
2016-12-17 09:48 PM
2016-12-17 10:18 PM
Richard wrote:THANK YOU, DID THAT, WORKS FOR NOW!
One last thing to check. Select the grid markers in the plan view, open them, and make sure that "3D view">"display in 3D view" is checked.
If that's already checked, then you may have to draw the grids in manually. (I like a line with a big round arrow head.)
2016-12-20 01:50 PM
2016-12-20 04:06 PM
DGSketcher wrote:That is true but since Elevations and Sections are generated form the 3D View hiding them in 3D can cause this bug.
I think I read somewhere that the grid line has to intersect the cutting plane (elevation or Section) to appear in the view.
another Moderator
