2015-08-0409:00 PM - last edited on 2023-05-1703:50 PM by Gordana Radonic
2015-08-0409:00 PM
I have used the Generic Label to report the ID and the Surface area of a composite Roof. It was reporting about 2 times as it should. I created a Fill of the same roof and the (normal to plan) area reported correctly. Since the roof surface is pitched (only 1:12 in this case) you could expect the actual surface area to be larger the area calculated by a fill which is normal (or perpendicular) to plan surface. Yet is reporting a bit over twice of what you would expect.
Also if would be beneficial to have the plan area reported for rainfall area calculations and not the sloped surface area.
I haven't looked at it but I am wondering if the surface is simply give the total for all surfaces - top, bottom and sides?
One of the forum moderators. Versions 6.5 to 27 i7-10700 @ 2.9Ghz, 32GB ram, GeForce RTX 2060 (6GB), Windows 10 Lenovo Thinkpad - i7-1270P 2.20 GHz, 32GB RAM, Nvidia T550, Windows 11
The parameter Value should have a selection arrow that allows this parameter to be changed from Entire Surface Area to Sum of Selected Surfaces, which then adds parameters for surfaces to be added to the total.
I was using AC19, yet the Library part was the Generic Label 18 from the Migrated library. I will attempt this using the Generic Label 19 with the adjustments you show.
