jh_tri12
Getting floor plans to be in same location on different sheets
I'm still new here. How can you get each floor plan to show up in the same location on each sheet? I haven't had any success in searching for help so far.
Thanks
2 Solutions
Aaron Bourgoin
one method is to duplicate the first plan sheet and then link the drawing on the duplicate to the view for that level.
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 29 / AC29.1.0 USA
Rhino 8.30 Mac
MacOS Tahoe 26.4.1
Go to post
DGSketcher
Legend
Probably the easiest one if you're new to this... In the Layout Book go to your new sheet, go to the Navigator and rt-click on a sheet with a placed plan, then select "Show as trace reference". You can then add your new plan on your new sheet and drag it to align with the trace reference.
There are other options involving dragging copies and relinking, but they are a bit more complex to explain.
Go to post
6 Replies 6
Aaron Bourgoin
Rhino 8.30 Mac
MacOS Tahoe 26.4.1
DGSketcher
Legend
jh_tri12
Yes, this works well. Thank you!
The above (mostly) rely on each plan having points in common, so work in most cases.
Where each plan has no common wall corner/etc to align with the next... due to cantilevers, re-shaping, or whatever... the traditional method is to use the Hotspot tool - which places a visible-on-screen-only snappable point.  You can use one of the above methods, and - only if needed - place a hotspot somewhere on one plan view (in the Archicad layer) ... and then copy/paste it to every other story (the Hotspot tool is ancient... and does not have a 'display on all stories' function).  You can then use the snappable point to align stories to the same location on layouts using Trace Reference... or you can place a hotspot on your Master Layout and snap to that.
The use of the hotspot-per story also allows alignment of multiple plan views on a single layout.  For example, if the floor plan cut plane view cannot show an overhead mezzanine or a split-level plan as desired, generate two views... and snap them together on the layout.
Aaron Bourgoin
this works great as well, but remember to turn the trace reference off for each sheet you align this way. The trace reference will stay active and print along with the plan on that sheet.
Rhino 8.30 Mac
MacOS Tahoe 26.4.1
DGSketcher
Legend
I think that is dependent on your print settings @Aaron Bourgoin . I have never had that happen probably because the required print setting is off by default in my setup, but still one to watch and it can be useful on occasion.
