2006-05-03
03:24 AM
- last edited
2 weeks ago
Molinda Prey
2006-05-03 03:33 AM
2006-05-03 03:40 AM
2006-05-03 04:07 AM
2006-05-05 04:29 AM
Scott wrote:No-one said it was supposed to make sense.
A little bit of an odd place for that setting though
2006-05-05 05:27 AM
It would make more sense to me for the transparency setting to be in the Section / Elevation marker, as is vectorial hatching and shadows.Agreed for section/elevations. But I'm not so sure one would even need transparency in the S/E window, I never have. To me the S/E's are typically more for construction document drawings where you don't need to see what is beyond the window, only that there is a window. transparency is fine and good for the 3D imaging stuff.
2006-05-05 05:55 AM
2006-05-05 02:06 PM
Scott wrote:Scott:
You also brought up another point; when one changes the 3D settings, the 3D window always opens generating an unwanted image/waste of time. Do you know of a way to suspend that action?
2006-05-05 07:08 PM
Go to Options>Work Environment>User Preference Schemes>Imaging and Calculation>3D Window Rebuild Controls. After changing this, remember to Redefine your scheme to make the change part of your Work Environment.David,
2006-05-07 04:32 PM
Scott wrote:There shouldn't be any need to restart ArchiCAD. You do need to apply the settings when you make changes to the Work Environment.
David Maudlin wrote:Go to Options>Work Environment>User Preference Schemes>Imaging and Calculation>3D Window Rebuild Controls. After changing this, remember to Redefine your scheme to make the change part of your Work Environment.David,
That works great, however AC needs to be restarted for the change to take affect and/or work properly.
Thanks so much,
Scott
