mverbeek
Google Drive Publisher issues in Windows
Since recently we can't select shortcut folders from Google Drive on Windows in the Archicad publisher. The path is a bit strange and no longer visible under the windows interface in Archicad. Anyone with a solution how to make this work again?
On MacOS there are no issues.
Lingwisyer
Guru
If you actually click in the address bar, what does the address resolve to? You cannot navigate to the actual folder rather than the shortcut?
mverbeek
It gives acces to an hidden folder, but only on windows explorer, copy / pasting the path into Archicad publisher doesn't work
