archigreen
Why can't AC26 modify morph's segmentation?
I need high resolution on morphs.
When I change on:
DESIGN
MODIFY MORPH
MODIFY SEGMENTATION
MORE SEGMENTS/ DOBLE SEGMENTS
It doesn't do anything.
Graphisoft, any comments?
ArchiCAD 26
MacOS Monterey
MacBook Pro Apple M1 Max
64 GB
It may depend of the Morph's geometry. I think if the Morph geometry is composed of curved surfaces and curves, that can be made "higher resolution", but if it is made of polygons, you will not be able to make that more segmented or higher resolution.
Can you show the morph and indicate where you would like to see higher degree of segmentation/resolution?
