Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
SOLVED!
Wish complex profile offset modifiers were accessible within column segments
I wish complex profile offset modifiers were accessible within column segments.
1 ACCEPTED SOLUTION
Solution
Hey Ignacio, that's already possible:
Or is there something else you mean?
POSIWID – The Purpose Of a System Is What It Does /// Ā«Furthermore, I consider that Carth... yearly releases must be destroyedĀ»
4 REPLIES 4
It seems to be the case?
I'd love to be able to access modifiers in complex profiles embedded in GDL objects, though.
ā€ƒ
Archicad 27 - GDL - PYTHON
When the profile is used within a segmented column. So that the offset values can be modified for that instance, that column segment.
An offset modifier values panel accessible from the settings for that complex profile column segment. (Beam segments too, for that matter.)
Solution
Oh man. I was expecting it to appear within ā€œStructureā€, where you set all the other section parameters.
The time I've wasted.
Thank you.
