yesterday - last edited yesterday by Barry Kelly
Hi all,
I appear to have come across a minor bug with Graphic Overrides...
In my situation, the order I set the a criteria seems to have an impact on the outcome. In the images below the dimension is in the last listed DO. When adding the criteria for it, if I set the filter to exlude THEN select the status, the dimension gets overriden. If instead I set the status, THEN set to filter to exclude, the dimension is excluded from the GO as expected. In the first situation, if I swap the status to include, then back to exclude after setting the status, it works... It only seems to be an issue when first adding the new criteria, as once set, changing the status or filter works as expected.
Ling.
Operating system used: Windows W11 25H2
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 7800X3D | 32GB | RTX5070TI |
