Graphic override works for single skin composites but not multiple skin composites
artktecture
I need to have 3 'color' choices for surfaces such as siding, stucco, and paint, and want them to display with different shaded background fills in section and elevation.
The surfaces are named:
Siding - Color 1, Siding - Color 2, Siding - Color 3
Stucco - Color 1, Stucco - Color 2, Stucco - Color 3
Paint - Color 1, Paint - Color 2, Paint - Color 3
I have 2 graphic overrides to set the fill background pen of surface names that contain:
'Color - 2' to pen 92 light grey, and
'Color - 3' to pen 94 dark grey
This override works on composites containing a single skin, however it does not work on composites with multiple skins, even though some of the skins are identical to the single skin composites.
Any idea how to get this to work on multiple skin composites?
artKtecture uses Archicad 24/Twinmotion
Lenovo Thinkpad | Xeon E2176M@2.70 GHz | 32GB | Quadro P4200 8GB
Oculus Rift S VR tours
Contour Rollermouse Red Plus (ditch your mouse and get one of these!)
Using a highly modified Shoegnome template (Thanks Shoegnome!)
Graphic Overrides will affect the entire element.
You can not override individual skins.
artktecture
thanks, I guess I'll try something else
