‎2020-10-22
07:38 PM
‎2023-05-23
03:04 AM
Gordana Radonic
‎2020-10-22 07:56 PM
‎2020-10-22 10:12 PM
‎2020-10-23 03:27 AM
‎2020-10-23 07:54 AM
FFFFF wrote:Yes, it can. Simply create a new schedule (Schedule -> Elements -> right mouse button -> new). Add type element - morph, if you need - add storey and layers (at the top window). At the bottom window you can add element's ID, volume, quantity (in the schedule put checkmark for "Merge Uniform Items" - if you have some same parameter for the same morphs - colour or smth else) and sadly ONLY 3D-isometric view, idk why AC doesn't display side views.
can archicad schedule and view the morphs?
I am on AC22 at the moment.
‎2020-10-23 03:47 PM
FFFFF wrote:Hello,
So i guess if the morph has to change then I would need to make a new gsm object every time it changes correct?
‎2020-10-24 09:52 AM
FFFFF wrote:I invite you to use Element ID like its name.
I really need to change my display name not sure how to do that.
‎2020-10-27 02:40 AM
‎2020-10-27 08:33 AM
I invite you to use Element ID like its name.Each block (morph, object, wall, slab, etc.) have a Element ID like into the orange rectangle :
Finally you are able to use label tool to make Element ID (name) visible on views.With this tool ...
‎2020-10-28 12:47 AM
