SOLVED!
Graphical overwrite - no control over individual material in walls?
cs_ryl
Hi All,
I want to know if it's possible to use Graphical Overwrite to highlight individual wall layers? See example below:
I have a composite wall with Brick+Cavity+Stud+Interior lining. On a plan that's Showing Entire Model, I would like to be able to highlight Cavity (under the Air Material) so that it can have its own fill and line type/weight/colour, and subsequently controlling the appearance of each individual wall buildup layer in the same way.
I'm able to create a rule that picks up Wall+Material Name, but it highlights the entire wall, instead of only the Cavity layer.
Overwrite rules for testing purpose - I noticed that Materials can only be selected as "Contain/Doesn't Contain", instead of "Is" - which might be why it's selecting the whole thing?
I am looking for something that allows for selection of individual material, or building composite layer. Any help would be appreciated!
AC23 AUSTRALIA
MacBook Pro M1 2020 8GB Memory | macOS Monterey 12.3.1
1 ACCEPTED SOLUTION
Solution
No, Graphical Overrides will override the entire element, even if only one part of it matches the criteria that you want to override.
There are quite a few wishes for this.
Here is one wish that has links to a few others as well.
https://community.graphisoft.com/t5/Wishes-forum/Graphics-Override-Components/m-p/304619
Feel free to like any or all of them.
6 REPLIES 6
Solution
Lee Hankins
I’m not sure you can do that. I know it doesn’t work with doors as the Graphic Overrides cannot search sub element materials. I’ve been trying to set one up that will file an opaque glass material in a door leaf and override it but it doesn’t work because it’s not possible to identify the sub element materials. I suspect this is the same for composites.
Lee Hankins
ArchiCAD 4.5 - Archicad 29
macOS Tahoe (26.0)
Turit
Graphic override does not work. The only way to highlight this is to get a pen number for the cavity that you don't use elsewhere. Then you can change the color with another set of pens.
For example:
Thanks Lee!
AC23 AUSTRALIA
Thanks Barry!
By skin type is definitely needed!
I will go through the links and give likes!
AC23 AUSTRALIA
oh @Turit can you please elaborate further here? I can't seem to figure out what you did there to change the colour - is it setup under a completely new pen set?
AC23 AUSTRALIA
