partial structure display for dimension
How can I get my dimensions to not turn off when I switch from entire model to partial structure display. The dimensions are to a slab with no composite finishes.
19 REPLIES 19
You can't.
Each partial structure display has to be dimensioned separately.
Erwin Edel
Sadly you can't copy them over in any way either. Learned that the hard way after dimensioning in the 'wrong' partial display for a few hours.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
felcunha
You can copy/paste into a worksheet then copy/paste back into your plan/cut view...
Felipe Ribeiro Cunha
AC 26, macOS Monterey
But they will be static dimensions and not associated to any elements.
Eduardo Rolon
But Static dims can become associative by relinking the nodes. Instead of using the worksheet you can also:
1. Select all Dimensions you want to copy
2. Change them to Static
3. Use CMD/CTRL + C to copy them
4. use CMD/CTRL + to undo the conversion to static
5. Switch to the correct PSD
6. Paste and relink as necessary
I use this method to copy paste dims between different drawings if necessary
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
Eduardo,
What is step 4? CMD/CTRL + what?
You mean CMD/CTRL + V?
My understanding is that once a Dimension is turned to static, it cannot be made associative again. You would have to recreate the dimension points to make them associative again.
Am I missing something?
Eduardo Rolon
Those are copy/paste and if you use undo after copying the static dim then it becomes associative again.
AC28 US/INT -> AC08
another Moderator
Ah, OK, so I Undo after Copy, that way the original Dimension will revert to being associative (while the copied instance will remain static). Got it.
How do you relink dimensions? adding a new node ? or is there a command for it?
