Graphisoft Project review on portable devices
Call for programmers: make "Graphisoft Project review" can be read on mobile devices, Android or IOS. It would be much more useful than portable VBE (or Bimx). You should write it in "SDK" instead of "Java" or something similar...
Thank's
10 REPLIES 10
Vote 'Essential'
... what aspects of the project in a 'project review' that would differentiate it from BIMx ??
In AC since we are 'modeling' rather than just 'drawing' isn't the killer portable app a model viewer rather than a drawing/schedule viewer? You can do that now (beautifully) with PDF's
.... unless you had something else entirely in mind
With GPR you can import mark-ups and these are imported in order by date, or name of the user, etc ... you can submit the changes to customers and manufacturers, and these will always be ordered. It 'a specific application which works well. The difference is between copying and importing.
.... and in construction sites (sorry, I'm Italian), you often work with plans and sections, rather than 3D models.
How about the Project Reviewer of ArchiCAD?
When you publish stuff as DWF for example, you can attach the Project Reviewer web environment which is Java-based. That should run in an browser.
Then you can do redlining in it.
I don't know how that would work with ouch-based devices though.
At a guess I would say it would be painful.
That's funny.
.... exactly on the same way.
"Ouch" devices do not read Java applications for a problem with Oracle licensing, so the Project Review does not work on them. The nice thing is that the language SDK (which runs on Android), and Java are virtually identical. Perhaps it would simply rewrite the web environment for Android (or iOS)in SDK instead of Java and throw it as great news for Tablet with the launch of VBE for iPad/iPhone.
Arkilario,
Could you create a wish for this?
It can be communicated better to GS HQ as a legitimate wish if man people support it as a wish.
