Martin Jan Rosa
BIMx down?
When publishing to BIMx I encounter a problem: I get the message "Unable to connect to BIMx Model Transfer site in Archiad". At the same time, when I try to connect to bimx.graphisoft.com and upload a hyper model manually, I can't log in - I get the message "You are not logged in or your session has expired" or "An unexpected error occurred during the reques (Err Code 33)". I tried it on several devices, AC26 INT and CZE, both build 5002. Is there by any chance a failure of the BIMx service, or could the problem be on my side (until recently everything worked OK)?
Snímek obrazovky 2023-08-11 v 18.51.58.pngSnímek obrazovky 2023-08-11 v 18.38.33.pngBIMx model transfer.jpeg.png
Martin Jan Rosa
Freelance Architect and BIM consultant
martinrosa.cz | Linkedin
GRAPHISOFT Certified Archicad BIM Manager, 2021, 2023, 2025 | Archicad 29 CZE | macOS 26 | MacBook Pro M3 Max
1 Solution
Martin Jan Rosa
I noticed the message https://community.graphisoft.com/t5/Graphisoft-Insights/Temporary-service-outage-for-Graphisoft-ID/b... - and I guess my problems will be related to this outage. 😉
Martin Jan Rosa
Go to post
Martin Jan Rosa
Martin Jan Rosa
Noemi Balogh
Hi @Martin Jan Rosa ,
Our system is up and running again. Please try again connecting to our BIMx transfer site.
Kind regards,
Noémi
Noémi Balogh
Senior Community Expert, Admin
