2023-08-11 07:04 PM
When publishing to BIMx I encounter a problem: I get the message "Unable to connect to BIMx Model Transfer site in Archiad". At the same time, when I try to connect to bimx.graphisoft.com and upload a hyper model manually, I can't log in - I get the message "You are not logged in or your session has expired" or "An unexpected error occurred during the reques (Err Code 33)". I tried it on several devices, AC26 INT and CZE, both build 5002. Is there by any chance a failure of the BIMx service, or could the problem be on my side (until recently everything worked OK)?
Solved! Go to Solution.
2023-08-11 11:17 PM
I noticed the message https://community.graphisoft.com/t5/Graphisoft-Insights/Temporary-service-outage-for-Graphisoft-ID/b... - and I guess my problems will be related to this outage. 😉
2023-08-11 11:17 PM
2023-08-12 05:55 PM
Hi @Martin Jan Rosa ,
Our system is up and running again. Please try again connecting to our BIMx transfer site.
Kind regards,
Noémi
Noémi Balogh
Staff Community Expert, Admin
