2006-06-05
09:40 PM
2023-05-30
10:09 AM
Rubia Torres
2006-06-06 04:45 AM
No idea what Rob is talking about. Maybe he can show us how to do that!ehm, sorry for misunderstanding I haven't read the second half of the original question - skimming the text is a bad habit and it sometimes does not work...
2006-06-06 06:56 AM
2006-06-06 01:03 PM
Mike wrote:It is not possible to adjust it.
Here is an image of the grids as I have been able to have them display in section views, but I am having trouble adjusting the vertical position of the grid marker as shown in the attached image.
2006-06-06 03:08 PM
Archi wrote:I have been able to adjust the position of the markers to get the desired output, but the process is far from intuitive. It appears that you need to do this with a combination of the settings in the section dialog box and the settings of the grids themselves while they are selected in a sect/elev window. Using the editable hot spots does not seem to work since as Archi User 77 pointed out if you change these and then reopen the sect/ elev window the settings revert to what they were previously.
You must shut off the link with grid in section and elevation, and draw new by yourself.
If you change the position of grid in section, in the next time again the further position will be taken.
Not so good marker...
2006-06-06 03:35 PM
Mike wrote:Mike,
The method that I found to work is the vertical position of the "marker head" in the sect/elev window needs to be adjusted in the sect/elev selection settings dialog box using the "length" setting in this window (see previous posted image where value was set to zero). In my case I set this to 125' and it set the markers in the position in the attached image. Go figure what the 125' actually means. This setting can be set to multiple placed sect/elev if they are all selected on the floor plan and you go to the settings dialog box. The length of the line needs to be adjusted in the "grid element setting" when the grid lines are selected while in the sect/elev window. Look at the marker tab - geometry - length. Unfortunately this needs to be done in each sect/elev window on an individual basis.
This seems like a tool we should have had long ago and I anxiously await when the sect/elev markers will do the same. Hopefully when they are able to achieve this ability the settings will not be so cryptic...
2006-06-06 03:40 PM
Matthew wrote:It feels a bit like that sometimes and always remember to cross your fingers before trying any new setting....
Mike,
You forgot to say that you also need to make sure you are standing on one leg and playing a kazoo while you adjust the markers. And BTW it doesn't work on the third Tuesday of the month, except in Romania, France, England and Paraguay where it is the second Wednesday.
I guess this was just obvious.
2006-06-06 04:33 PM
2006-06-06 07:59 PM
2006-06-06 08:05 PM
2006-06-06 08:09 PM
