ā2006-06-05
09:40 PM
ā2023-05-30
10:09 AM
Rubia Torres
ā2006-06-06 08:35 PM
ā2006-06-06 08:38 PM
ā2006-06-06 08:46 PM
ā2006-06-06 09:25 PM
g.h.design wrote:Select the grid lines while in the sect/elev window and adjust the same setting that you use in the floor plan view to control which side the marker is on. Although it appears that this will change your floor plan display, it only affects the markers in the sect/elev window.
Yeah, I have both on in floor plan but they are at the bottom in section.
I can get them to the top by entering a negative number in the parameter_geometry_length but the line ends up bisecting the bubble...
ā2006-06-06 09:57 PM
ā2006-06-06 10:17 PM
ā2006-06-06 10:39 PM
ā2006-06-06 11:50 PM
ā2006-06-07 12:24 AM
g.h.design wrote:Now that is consistency for you. I hope when I get these set in my template they will transfer to windows users without incidence...
I am afraid windows version doesn't have that available in the section window... only symbol attributes and cut surfaces attributes under "floor plan and section" toggle.
ā2006-06-07 01:02 AM
