ā2006-06-05
09:40 PM
ā2023-05-30
10:09 AM
Rubia Torres
ā2006-06-09 11:30 AM
ā2006-06-13 07:38 AM
ā2006-06-14 09:24 AM
owen wrote:We identified this as a bug: hotlinking files, which contain CIRCULAR grid elements makes some elements - or the completre hotlink disappear.
Can you respond to my post regarding this tool working when Hotlinked into another file.
ā2006-06-14 09:27 AM
ā2006-06-14 04:46 PM
Brad wrote:I have been able to edit the grid position and length, but not by using the hotspots. I have had to use a combination of the grid settings in the sect/elev default settings, and the settings of the grid tool itself when the grid is selected in a sect/elev window. some of these changes can be made by selecting all of the sect/elev that want to show grids and change them all at once, but some need to be changed in each "open" sect/elev. This is unfortunate - perhaps in the next generation we will have one more tab that addressees grid display in sect/elev windows such that changes can be made globally across the whole project with a toggle to have individual control within certain sect/elev windows.
Unfortunately this has to be classified as another "ArchiCAD almost works but totally useless tool"TM. As noted earlier you can not get the grid elevation correct in the section elevation tool. It always reverts to its initial arbitrary elevation. You can lock the grid in elevation which keeps it there but then if you move the grid in plan it can't update. But the auto dimensioning will move so it will no longer snap to the grid. Also the auto dimensioning in plan is not live so if you move the grid the static dimension remains. Not an expected ArchiCAD behavior. If anyone can prove me wrong please do.
ā2006-06-14 05:11 PM
ā2006-06-14 06:20 PM
Brad wrote:I have just started playing with this in the last week or so, but I believe I have a method that works.
I'm glad to see that there is some action on this part and hope that it will become useable shortly.
Mike, My problem is that it seems almost impossible for you to describe your process that works in a fashion that other people can duplicate it easily. How do you select all the sect/elev at once? Do you have full confidence that if you have to modify the grid it will update properly across all drawings without you having to reset everything again?For now I have a much faster and more flexible traditional way which is copy and paste from the plan.
ā2006-06-14 06:48 PM
2. Adjust position of grid markers in section and elevation views. This is the step that can be done to all section and elevation that are currently placed on your plan in a single step. In the plan window select all of the sections and elevations. Open the "section/elevations selection settings" dialog box and adjust the "length" setting under the "grid tool" tab. This will adjust the position of the grid marker bubble in your sections and elevations.Problem is I don't have a Grid Tool tab in my section/elevation selection settings window.
ā2006-06-15 04:37 AM
ā2006-06-15 05:02 AM
