HELP FILES
hello everybody. I am a new user of archicad and I would like to know if there could be a way to access offline the help documentation. I am really confused about some functionalities of archicad and sharing with me some best practices that helped you move on when you were a first user will be a good help.
Erwin Edel
It should come shipped with PDF documentation available from the help menu.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
In the ARCHICAD application folder you will find the Documentation folder, which contains the PDF files Erwin mentioned.
There is also a Help folder which contains the offline Help files in html format.
