Help! Major Library Management Issues
We are doing our first guinea pig project in Archicad 9 (through Teamwork) and Plotmaker 9. We had several successful plots out of Plotmaker before we started encountering problems:
- Some drawings brought into Plotmaker are encountering library loading problems. It seems to be an issue where BG AC isn't able to find the libraries.
- Fonts are not registering on our floor plans. The same font appears correctly on the titleblock, but has been substituted in the floor plan.
It seems that these may be issues related to some confusion we have about the best way to manage libraries, in teamworks, over a server.
Any advice you could give would be MUCH appreciated!
Thanks,
Abby
1 Reply 1
__archiben
Abby wrote:
We are doing our first guinea pig project in Archicad 9 (through Teamwork) and Plotmaker 9. We had several successful plots out of Plotmaker before we started encountering problems . . .
not necessarily for archiCAD 9 specifically, but there are thoughts, ideas and principles here that may help:
http://archicad-talk.graphisoft.com/viewtopic.php?p=18889#18889
http://archicad-talk.graphisoft.com/viewtopic.php?p=2350#2350
http://archicad-talk.graphisoft.com/viewtopic.php?t=2561&postdays=0&postorder=asc&start=0
http://archicad-talk.graphisoft.com/viewtopic.php?t=1960&start=0&postdays=0&postorder=asc
HTH
~/archiben
b e n _ f r o s t
